GPS rec and BT module
Hello all,
I have 1 GPS-09133 and want to make it talk to my htc6800 through BT. I assume that I can attach a WRL-08474 BT module with rx/tx and power, configure the BT module, store the config to flash, through all of that in a small project case with a li-poly, pair it to my HTC and off I go. Is it that simple? No micro or anything to glue the two together? I do not have much experience with BT stuff, hence the question. I assume that by storing the settings to flash in the BT module that everytime I turn it on (along with the GPS rec) it will go ahead and re-pair with the HTC as long as it’s around and turned on. Any advise would be appreciated. Thanks
jkt
