Howdy, has anyone used the GPS-RTK-SMA board to log raw L1/L2 data in UBX format, for example using Open Log? I just want to use this board in a non-RTK application for collecting raw data in a remote location (static point survey). I need to configure the output of the F9P in uCenter and then when I power the board I want it to automatically start collecting raw data and save it to an SD card.
Such a basic question, but no response. Sigh… Come on Sparkfun give me some info or send me a board for free and I will check it out for you!
So… you’re upset that it wasn’t answered in less than 24 hours? They have a sticky detailing how to get help and expected timelines. viewtopic.php?f=59&t=49379
Once you have created your post a Technical Support Representative will review the topic shortly and will respond to the post in about 3 estimated business days if it fits our criteria for technical support eligibility.
If they haven’t done it in the tutorials then you’ll probably have to do that research and work yourself. Should be easy to check the datasheets and Ublox documentation: https://www.u-blox.com/en/product/zed-f9p-module
Here is an example of what you ask for: https://github.com/PaulZC/F9P_RAWX_Logger
