Grab the edge/center of a group in Eagle for panelization?
Typically when you want to grab the center of a component you can press Ctrl+left click, this will snap to your grid. Is there a way to do this for a group of components? I am trying to panelize a board and have copied in the second board, but I can’t get the copied board to lineup with my grids. Thanks.
Why don’t you use the panelize ULP script?
Thanks for the quick reply and I could be wrong, but the ULP script seems to be for naming under a panel setup. I think I found a solution: you have to copy and paste from within the same board for the grid system to attach. So I copy a new board in, then copy the board again and the native grid system seems to be working.
