Graphic OLED Color Display 128x128
are you guys also going to be selling the connector for this LCD ?
Until Sparkfun stocks them, all you need is a 30 contact 0.5mm pitch FFC connector. There are a number of them available from Digikey depending on what fits your application.
One example is the HFJ30CT-ND (Digikey part #) made by Hirose. This particular part is a bottom contact connector which means that the OLED display will face the opposite side of the board it is mounted on. There is a top connector version (HFK30CT-ND) but it isn’t in stock at the moment. To find more on Digikey, search for connector, then click the FFC/FPC (Flat Flex) link under the connectors heading. Next enter 30 contacts and 0.5mm pitch into the parametric search. You should come up with 2 pages of options.
Happy hunting!
-Bill
thanks much for the numbers and hlep.
