Graphics on PCB
This is more of a style question than practical but I’m curious:
How do you make or import graphics to a board in Eagle? I noticed the Sparkfun library has it and so does TI and AMD (and probably a few others). I looked around in the menus and did some google searching but couldn’t find anything about it
You can use the import-bmp.ulp (File->Run->import-bmp.ulp in the board screen)
I would recommend creating a new layer and putting the graphic on it. It will also take some work to get the resolution/scaling right.
That worked, thanks
Re: new layer, i think the script does that automatically as I now have a layer called 200bmp that didn’t exist before.
