Hi all, I would appreciate some guidance on hardware setup for the following:
Background:
Automated table top plastic injection molding machine using the following (minimum) hardware components:
(4) pneumatic valves (relays)
(2-4) contact position sensors
(1) thermistor
(1) thermocouple
(1) stepper motor (connected to screw to feed plastic pellets into hot chamber)
Possible future additions:
(1) relay for small coolant pump control based on thermistor output.
My question is, I have been searching for available hardware and have pretty well settled on the Arduino Mega platform due to the number of I/O I will need. I believe I will need a relay shield, probably the 8 relay shield by sparkfun, a stepper motor driver, thermocouple amplifier?, and a sensor board?
While looking at some of the hardware components it seems some have stackable headers while others do not, I have not found a stepper motor controller with stackable headers. I was really hoping to keep the install clean as one unit and not have jumpers running to individual boards but is this a pipe dream?
Any recommendations on if I can actually use all of this hardware on one MEGA (with aux. Power supply) would be appreciated.
Ps. I’m a mechanical guy so if possible please dumb down the electrical jargon for me ![]()
