Having a little trouble with buttons
I’m playing with the SIK, with the help of the guide I’m slowly learning, I’m working on a script that will light up the LED of the button you press unless you press yellow and blue simultaneously, in which case the Green LED will light-up, for now I’m just working on getting the buttons to work with the LEDS, as I have it now the script looks like this
const int GnBttn=2; //Declares "GnBttn" as a Constant and Sets Value
const int RdBttn=3; //Declares "RdBttn" as a Constant and Sets Value
const int BlueBttn=4; //Declares "BlueBttn" as a Constant and Sets Value
const int YlwBttn=5; //Declares "YlwBttn" as a Constant and Sets Value
//5
const int GnLED=8; //Declares "GnLED" as a Constant and Sets Value
const int RdLED=9; //Declares "RdLED" as a Constant and Sets Value
const int BlueLED=10; //Declares "BlueLED" as a Constant and Sets Value
const int YlwLED=11; //Declares "YlwLED" as a Constant and Sets Value
//10
void setup()
{//12
  int Bttns[] = {YlwBttn, GnBttn, RdBttn, BlueBttn}; // Declares "Bttns" as an index and sets the values equal to the Bttn Variables
  int LEDs[] = {YlwLED, GnLED, RdLED, BlueLED}; // Declares "LEDs" as an index and sets the values equal to the LED Variables
  int index; // declares "index" as a variable
  for (index = 0; index <= 4; index++)//Creates For loop, sets "index" to 0 at beginning, runs when "index" is less then or equal to 4, adds one to "index" each time it runs
  {//17
    pinMode (Bttns[index], INPUT); //Sets Pin# "Bttns[index]" as an Input
    pinMode (LEDs[index], OUTPUT); //Sets Pin# "LEDs[index]" as an Output
    digitalWrite (LEDs[index], HIGH); //turns on "LEDs[index]"
    delay(100);//waits 100 Milliseconds
  }//22
  delay(100);// Waits 100 Milliseconds
  {//25
    digitalWrite (LEDs[index], LOW);//turns off "LEDs[index]"
  }//26
}//30
//31
void loop()
{//33
  int YlwBttnState; //Declares "YlwBttnState" as a variable
  int RdBttnState; //Declares "RdBttnState" as a variable
  int GnBttnState; //Declares "Gn BttnState" as a variable
  int BlueBttnState; //Declares "BlueBttnState" as a variable
//38
  YlwBttnState=digitalRead(YlwBttn); //Sets Value of "YlwBttnState" to value read from pin "YlwBttn"
  GnBttnState=digitalRead(GnBttn); //Sets Value of "GnBttnState" to value read from pin "GnBttn"
  RdBttnState=digitalRead(RdBttn); //Sets Value of "RdBttnState" to value read from pin "RdBttn"
  BlueBttnState=digitalRead(BlueBttn); //Sets Value of "BlueBttnState" to value read from pin "BlueBttn"
//43
//44
  //When a Button is Pushed it will be read as LOW
  if (RdBttnState==LOW) //if Value of "RdBttnState" is off
  {//47
    digitalWrite  (RdLED, HIGH); //Send Power to pin "RdLED"
  }//49
  else//50
  {//51
    digitalWrite  (RdLED, LOW); //Turn off pin "RdLED"
  }//53
  //54
  if (GnBttnState==LOW) //if Value of "GnBttnState" is off
  {//56
    digitalWrite  (GnLED, HIGH); //Send Power to pin "GnLED"
  }//58
  else//59
  {//60
    digitalWrite  (GnLED, LOW); //Turn off pin "GnLED"
  }//62
  //63
  if (YlwBttnState==LOW) //if Value of "YlwBttnState" is off
  {//64
    digitalWrite  (YlwLED, HIGH); //Send Power to pin "YlwLED"
  }//66
  else//67
  {//68
    digitalWrite  (YlwLED, LOW); //Turn off pin "YlwLED"
  }//70
  //71
  if (BlueBttnState==LOW) //if Value of "BlueBttnState" is off
  {//73
    digitalWrite (BlueLED, HIGH); //Send Power to pin "BlueLED"
  }//75
  else//76
  {//77
    digitalWrite (BlueLED, LOW); //Turn off pin "BlueLED"
  }//79
}//80
and the circuitry looks like this:http://i1026.photobucket.com/albums/y32 … dligin.png
When I push the red or yellow buttons it works as expected, but the blue LED is always on, regardless of the state of the blue Button, and the yellow LED is always off, regardless of the state of the yellow button.
I’m farly certain it is a code problem because when I switch out components it has no effect on how the Circuit works.
Any help is much appriciated.
You indicated that yellow works as expected, then you say it's always off... green must be in the equation also, somewhere.
Your setup routine appears to turn on each LED, 100 mSec for the first, an additional 100 mSec for the second and so on. Do they all light up? You can increase this time to see if they do.
You haven’t diagnosed this to a button issue or LED issue?
Also noticed that you set up an array for the buttons and LEDs but have only 4 elements. Since the arrays are zero based, 0 through 4 is five items, not 4.
So, your setup function loop should be:
for ( index=0; index < 4; index++ ) {
or <= 3 would also work.
Both the loops in setup () are that way.
This will certainly affect the pinMode and likely screw up the desired results.
Fixed the pin setup as suggested, working fine now.
I cant believe I missed that. :oops:
Thanks for the help.
