The sparkfun-qwiic package for python appears to be fundamentally broken on my RaspberryPi3 (raspbian version Jesse)
Specifically, I successfully installed the module using
sudo pip3 install sparkfun-qwiic
but when I run the following simple program
import qwiic
# attempt to get list of current devices (fails!)
results = qwiic.list_devices()
print(results)
I get the error traceback
File “./qwiic.py”, line 3, in
import qwiic
File “/home/pi/Programs/qwiic.py”, line 9, in
AttributeError: ‘module’ object has no attribute ‘list_devices’
This error first came up under Python 2.7, and I thought upgrading to Python 3.4 might fix it, but no such luck.
I also tried dir(qwiic), and it confirms that there are apparently no callable functions/methods of any kind associated with the module. I couldn’t find any mention of this problem by anyone else, so there must be something peculiar about my setup. I haven’t had a similar problem with any other Python module.
So the problem described above goes away if I copy the source code file at https://raw.githubusercontent.com/spark … init_.py to a file qwiic.py in my working directory. This suggests that there’s something wrong with the installation process rather than the code itself. Since I don’t know what happens under the hood when a module is installed, I’m not sure how to track down the problem.
Have you had any luck? I just got my Qwiic kit and I’m stuck at the part trying to install Qwiic following their guide.
sudo pip install sparkfun_qwiic
sudo: pip: command not found
I did sudo pip3 install and that seemed to work, but still can’t get Qwiic to work. I continue to work through all the broken and missing modules until I think I get it to work and run the test code:
but when it comes time to run the actual program I’m met with so many “has no attribute” errors
File "qwiic_kit_for_pi_demo.py", line 64, in <module>
oled.setFontType(1)
AttributeError: 'QwiicMicroOled' object has no attribute 'setFontType'
comment out that section and…
File "temp.py", line 93, in <module>
proximity = prox.getProximity()
AttributeError: 'QwiicProximity' object has no attribute 'getProximity'
DamagedDolphin, I believe you posted this issue on the tutorial [here and a member of our tutorials team responded with some information about the issue and an update for the GitHub repo that should fix it.
