hi everybody
i still face problems with the receiver… :?
i have changed the clock to 4Mhz…
i’m posting the assembly code of the receiver module…
please give me sugestions… or the modifications required…
swapnil
LIST P=16F73
#INCLUDE <P16F73.INC>
__CONFIG _BODEN_OFF & _CP_OFF & _PWRTE_OFF & _WDT_OFF & _XT_OSC
#DEFINE CE PORTC,7 ; OUTPUT ONLY
#DEFINE CS PORTC,6 ; OUTPUT ONLY
#DEFINE DR1 PORTC,2 ; INPUT ONLY
#DEFINE LED1 PORTB,7 ; OUTPUT ONLY
#DEFINE LED2 PORTB,6 ; OUTPUT ONLY
#DEFINE KEY1 PORTB,3 ; INPUT ONLY
#DEFINE KEY2 PORTB,2 ; INPUT ONLY
ORG 0X0000
; MEMORY CONFIGRATION
; 15 BYTES OF CONFIGRATION WORD
; CONFIGRARION BITS OF MODULE SEND COUNTER ( 0F COUNTS )
CBLOCK 0X20
CON_ARR: 0X0F ; CONFIG ARRAY
CON_COUNT ; CONFIG COUNTER
DEL3MS1REG ; DELAY REG
DEL3MS2REG ; DELAY REG
SENDREG ; REG TO SEND DATA
READREG ; REG TO READ DATA
ENDC
GOTO START
; PORT CONFIGRATION
START
NOP
; PORT B RB7 & 6 LEDS, RB2 & 1 INPUT KEYS, REST OUTPUTS
BANKSEL TRISB
MOVLW 0X06 ; B 0 0 0 0 0 1 1 0
MOVWF TRISB
; PORT C INPUT ( SPI & CONTROL SIGNALS OF TRW-24G )
MOVLW 0X14 ; B 0 0 0 1 0 1 0 0
MOVWF TRISC
; CONFIGURE SPI
MOVLW 0X40 ; SMP = 0 SAMPLE AT MIDDLE..
MOVWF SSPSTAT ; CKE = 1 DATA TRANSMISSION ON RISING EDGE
; ENABLE SPI
BANKSEL SSPCON
MOVLW 0X21 ; SSPEN=1 SSP ENABLE, CKP=0 IDLE STATE CLK IS 0
MOVWF SSPCON ; SPI MASTER FOC/16
; TRW-2.4G MODULE CONFIGRATION
; INITIALISE FSR
CALL DELAY3MS ; WAIT FOR RF MODULE TO START
MOVLW 0X20
MOVWF FSR
; LOAD 15 BYTES OF CONFIGRATION DATA NO TEST BITS WRITTEN
MOVLW 0X00 ; DATA2_W 8 BIT DATA ON CHANNEL 2
MOVWF INDF
INCF FSR,1
MOVLW 0X08 ; DATA1_W 8 BIT DATA ON CHANNEL 1
MOVWF INDF
INCF FSR,1
MOVLW 0X00 ; 5 BYTES OF ADDRESS ON R2
MOVWF INDF
INCF FSR,1
MOVLW 0X00
MOVWF INDF
INCF FSR,1
MOVLW 0X00
MOVWF INDF
INCF FSR,1
MOVLW 0X00
MOVWF INDF
INCF FSR,1
MOVLW 0X00 ; 40 BYTE ADDR
MOVWF INDF
INCF FSR,1
MOVLW 0X11 ; 5 BYTES OF ADDRESS ON R1
MOVWF INDF
INCF FSR,1
MOVLW 0X33
MOVWF INDF
INCF FSR,1
MOVLW 0X55
MOVWF INDF
INCF FSR,1
MOVLW 0X99
MOVWF INDF
INCF FSR,1
MOVLW 0XAA ; 40 BYTE ADDR
MOVWF INDF
INCF FSR,1
MOVLW 0XC3 ; ADDR_W & CRC
MOVWF INDF ; 8 BIT ADDRESS, 8 BIT CRC, CRC ENABLED
INCF FSR,1
; GENERAL CONFIGRATION
MOVLW 0X4F ; SINGLE RX CHANNEL
MOVWF INDF ; SHOCK BURST MODE
INCF FSR,1 ; 250 KBPS
; 16MHZ CLOCK
; 0 dB GAIN
; RF CHANNEL AND DIRECTION
MOVLW 0X05 ; RECEIVER
MOVWF INDF
; SEND CONFIGRATION WORD
MOVLW 0X0F ; 15 DEC = 0F HEX
MOVWF CON_COUNT ; LOAD COUNTER FOR 18 BYTES TRANSFER
MOVLW 0X20 ; REINITIALISE FSR
MOVWF FSR
BSF CS ; TO ENABLE WRITE TOTWR-2.4G CONFIGRATION
CALL DELAY5US
LOOPCONF
MOVF INDF,W
MOVWF SENDREG
CALL SENDDATA
INCF FSR,1
DECFSZ CON_COUNT,1
GOTO LOOPCONF
; END OF LOOP1
BCF CS ; ACTIVATE CONGIGRATION OF TWR-2.4G
CALL DELAY5US
GOTO MAIN
; SEND BYTE
SENDDATA
MOVF SENDREG,W
MOVWF SSPBUF
BANKSEL SSPSTAT
CHAR0
BTFSS SSPSTAT,BF ; WAIT TILL END OF TRANSMISSION
GOTO CHAR0
;LOOP CHAR0
BANKSEL SSPBUF
MOVF SSPBUF,W ; AT END OF TRANSMISSION THROW
; AWAY DUMMY RECEIVED DATA.
RETURN
; READ BYTE
READDATA
MOVLW 0X00 ; DUMMY DATA TRANSMITTED
MOVWF SSPBUF
BANKSEL SSPSTAT
CHAR1
GOTO CHAR1
;LOOP CHAR0
BANKSEL SSPBUF
MOVWF READREG ; STORE RECEIVED DATA.
RETURN
; 1uS DELAY FOR EACH INST.. AT 4MhZ
; 5uS DELAY
DELAY5US
NOP
; CALL = 2 uS, NOP = 1 uS, RETURN = 2 uS
; 1 + 2 + 2 = 5 us
RETURN
; 3mS DELAY
DELAY3MS
MOVLW 0X03
MOVWF DEL3MS1REG ; 1ms X 3 = 3ms
LOOP3MSOUT
MOVLW 0XFA
MOVWF DEL3MS2REG ; 4us X 250 = 1ms
LOOP3MSIN ; T
NOP ; \|/
DECFSZ DEL3MS2REG,1 ; V
GOTO LOOP3MSIN ; 4 us DELAY
; INNER LOOP
DECFSZ DEL3MS1REG,1
GOTO LOOP3MSOUT
; OUTER LOOP
RETURN
MAIN
BANKSEL PORTB
BCF LED1 ; POWER ON
BSF CE ; START LOADING 8 BIT ADDRESS
; & 8 BIT DATA
CALL DELAY5US
READTEST
BTFSS DR1
GOTO READTEST
CALL READDATA
MOVLW 0X66
SUBWF READREG,W
BTFSC STATUS,Z
GOTO READTEST
MOVLW 0X40
XORWF PORTB,F
NOP
NOP
GOTO READTEST
END
please post the corrections…
i was able to receive junk data with 8 bit adderss and 8 bit crc… but nothing is received with 40 bit address and 16bit crc.
swapnil
