:arrow: Hi I’m interesting about RF(nRF24L01) .I see This application in this website and www.diyembeded.com and i follow it but it’s not work i don’t know about problem :?: Please tell me about this problem and or example
:o I use MCU p18F8720 ,xtal = 6 MHz, Compiler = CCSC PCWH 4.049
Is there any reason you aren’t using C18? That’s what this code was meant to be compiled on. The student version is a free download from Microchip, and is fully-featured for 60 days. After that, only some optimizations are disabled. Plus, it plugs into MPLAB IDE perfectly.
Also, you have to modify the delays in my source code if you’re not using a 10 MHz crystal with the PLL running (internal clock of 40 MHz) or a 40 MHz crystal with the PLL off (still an internal clock of 40 MHz).
