Help needed : gcc programs won't run on LPC-E2294
since friday i try to make some simple gcc-Examples work on a LPC-E2294. The code works fine on a LPC2106 and a LPC2194.
Also test-projects from the olimex-hp for LPC-E2294 can be compiled ans works with the IAR-toolchain, but with gcc nothing works. Has anyone a idea ???, is there any ‘nogcc’-jumper on the board ???
Peter
i think i got it work!!! The problem was, that the Boot0 and Boot1 pin at LPC2294 were connected to ground, so the examples and linker-scripts, designed for internal flash memory, couldn’t start.
Peter
