HELP NEEDED TO ADD AN LCD TO OLIMEX BOARD SAM-L9260
Have anyone here have tried to interface a LCD Display with its own Controller to the Olimex SAM-L9260 using RGB Interface.
I have seen RockBox project on this site which explains about interfacing a SPI based Nokia LCD display.
I wanted to interface a 16bit LCD with ILI9320 based Display. The Display has D[0…15], VCC,VSS,CS,RS,\RD,\WR,\RESET pins. I would like to use this display under Linux. Can someone help ?
VGSK.
