Help Please! AVR PG-2B Wont Recognize Key Counter
I have the dongle attached to my printer port and to my key counter. Connect the MINIDIN cable up and the power light goes on. When I try to program, however, with programmers notepad I receive the following output:
“make.exe” program
avrdude -p atmega168 -P lpt1 -c stk200 -U flash:w:Key-Counter-v11.hex
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
make.exe: *** [program] Error 1
Process Exit Code: 2
Time Taken: 00:00
EDIT: The new PonyProg seems to recognize the dongle since I enabled my parallel port in BIOS. But I still have this above error when I try to program. Ponyprog gives a similar message.
This is my first time trying to get this stuff working so a good description of where I might be going wrong or misunderstanding something would help me a lot. Thanks in advance!
PS. Should I wash my hands of this dongle business and buy a dragon?
http://img518.imageshack.us/img518/6272/pic1vv8.jpg
I disconnected it so I could take clearer pictures. When I actually attempt to program, I have the Minidin, keyboard, and dongle cables all connected (the power light on the key counter is on). I have no other cables connected because I’m under the impression that the DIN supplies the power that the dongle needs to program the counter.
Here is from the other side:
http://img156.imageshack.us/img156/9620/pic2gm5.jpg
I hope I did something pretty obvious and someone can help. :slight_smile:
