I have a problem with bluetooth matt 2 BC118 module, when activated in scan mode, this recognizes the other BLE devices, the detail is in not showing the names of these for over having 7 characters as specified in the datasheet, do you know any solution for this ?, or only recognizes the same type of chip ?.
thank you!
best regards! :dance:
If the datasheet says it can’t see characters after the 7th, then there’s nothing you can do…
Thank codlink
detail this in my devices have short names as mentioned in the datasheet, and I can not display the names of nearby devices, will it be recognized only modules of the same company? or will it be the type of service? :shock:
best regards
It should see all BT devices… But, don’t have experience with this module.
thanks for the help codlink
Maybe not even me have explained properly, commented, devices if visible, with its mac address and others, the detail is in the display of the names of the modules, I leave this to give an idea
Datasheet: SCN = B 20FABB000001 T 0 R E3 M 1 N BC00001 F 6
test: SCN B 001EC01D0A0D T 0 F 6 R CA M 0 :!:
