This the code:
#include <TinyGPS++.h> //GPS Library
#include <Time.h> //GPS
#include <TimeLib.h> //GPS
#include <SD.h>
#include <SPI.h>
#include <SoftwareSerial.h> //GPS
#include <LiquidCrystal.h>
//PM Code
int dustPin = 0; //Connect dust sensor to Arduino A0 pin
int ledPower = 5; //Connect 3 led driver pins of dust sensor to Arduino D2
int samplingTime = 280;
int deltaTime = 40;
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
//SD Code
/*Choose two Arduino pins to use for software serial
The GPS Shield uses D2 and D3 by default when in DLINE mode*/
int chipSelect = 4; //Set chipSelect=4
File AQ_GPSTemp_Data; //variable for working with our file object
//LCD Code
// initialize the library with the numbers of the interface pins 12-RS 11-E 9-6 - DPins
LiquidCrystal LCD(31, 30, 25, 24, 23, 22);
//GPS Code
//initialization for GPS
static const int RXPin = 2;
static const int TXPin = 3;
//Temp Code
//initialization for TempSensor
int val;
int temPin = 1;
float mv;
float cel;
// The Skytaq EM-506 GPS module included in the GPS Shield Kit
static const uint32_t GPSBaud = 9600; //Set GPS Baud Rate
const int UTC_offset = 8; // to correct the GPS UT time to the Phil. Local Time
int Year;
byte Month;
byte Day;
byte Hour;
byte Minute;
byte Second;
// Create a TinyGPS++ object called "gps"
TinyGPSPlus gps;
// Create a software serial port called "gpsSerial"
SoftwareSerial gpsSerial(RXPin, TXPin);
//initialization for SD
void setup()
Serial.begin(9600);
gpsSerial.begin(GPSBaud); //GPS Serial.begin
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized
if (!SD.begin(chipSelect)){
Serial.println("Card failed, or not present");
//dont do anything
return;
Serial.println("card initialized.");
pinMode(ledPower,OUTPUT); //PM output
pinMode(10, OUTPUT); //Reserve pin 10 as an output
SD.begin(4); //initialize the SD card with chipSelectect connected in pin 4
// set up the LCD's number of columns and rows:
LCD.begin(16, 2);
//MAIN LOOP
void loop()
// This sketch displays information every time a new sentence is correctly encoded.
while (gpsSerial.available() > 0) //enabling the GPS Module
if (gps.encode(gpsSerial.read()))
displayInfo(); //Provide the corresponding readings from the different sensors
/* If 5000 milliseconds pass and there are no characters coming in
over the software serial port, show a "No GPS detected" error*/
if (millis() > 5000 && gps.charsProcessed() <10)
Serial.println(F("No GPS detected"));
while(true);
void displayInfo() //Display Readings from sensors
GPSLocation(); //GPS latitude and Longitude
GPSDate(); //GPS Date in MM/DD/YY format
GPSTime(); //GPS Phil. time in HH:MM:SS format
TempSensor(); //Read Temperature Sensor
PMSensor(); //Read PM Sensor
/*LCD.setCursor(0,0); //Set LCD Cursor to upper left corner, column 0, row 0
LCD.print("TEMP:");
LCD.print(cel,4);
delay(250);
LCD.setCursor(0,1); //Set LCD Cursor to upper left corner, column 0, row 0
LCD.print("PM: ");
LCD.print(dustDensity,4);
delay(250);
LCD.clear();
AQ_GPSTemp_Data= SD.open("GPSData.txt", FILE_WRITE); //Open AirQuality_GPSandTEMP_Data.text on the SD card
//as a file to write the readings
if (AQ_GPSTemp_Data){
AQ_GPSTemp_Data.print(F("Location: "));
AQ_GPSTemp_Data.print(gps.location.lat(), 6); //latitude
AQ_GPSTemp_Data.print(F(","));
AQ_GPSTemp_Data.print(gps.location.lng(), 6); //longitude
AQ_GPSTemp_Data.print(F(" Date/Time: "));
AQ_GPSTemp_Data.print(gps.date.month()); //month
AQ_GPSTemp_Data.print(F("/"));
AQ_GPSTemp_Data.print(gps.date.day()); //day
AQ_GPSTemp_Data.print(gps.date.year()); //year
AQ_GPSTemp_Data.print(F(" "));
AQ_GPSTemp_Data.print(Hour); //hour
AQ_GPSTemp_Data.print(F(":"));
AQ_GPSTemp_Data.print(Minute); //minute
AQ_GPSTemp_Data.print(Second); //second
AQ_GPSTemp_Data.print(" TEMPERATURE=");
AQ_GPSTemp_Data.print(cel); //temp in degree celsius
AQ_GPSTemp_Data.print("*C");
AQ_GPSTemp_Data.print(" - Voltage: ");
AQ_GPSTemp_Data.print(calcVoltage);
AQ_GPSTemp_Data.print(" - Dust Density: ");
AQ_GPSTemp_Data.println(dustDensity); // unit: mg/m3
AQ_GPSTemp_Data.close(); //close the file
Serial.println();
//delay(10);
//Functions in the [displayInfo()].
void GPSLocation() //Location of the GPS
Serial.print(F("Location: "));
if (gps.location.isValid()) //checks if there is any valid information for the location
Serial.print(gps.location.lat(), 6); // Latitude
Serial.print(F(","));
Serial.print(gps.location.lng(), 6); // Longitude
else
Serial.print(F("INVALID")); // no valid info
void GPSDate() //Current Date
Serial.print(F(" Date/Time: "));
if (gps.date.isValid()) //checks if there is any valid information for the date
Serial.print(gps.date.month()); //month
Serial.print(F("/"));
Serial.print(gps.date.day()); //day
Serial.print(gps.date.year()); //year
else
Serial.print(F("INVALID")); //no valid info
void GPSTime() //Current Time
Serial.print(F(" "));
if (gps.time.isValid()) //checks if there is any valid information for the time
Year = gps.date.year();
Month = gps.date.month();
Day = gps.date.day();
Hour = gps.time.hour();
Minute = gps.time.minute();
Second = gps.time.second();
setTime(Hour,Minute,Second,Day,Month,Year); // Set Time from GPS data string
adjustTime(UTC_offset * SECS_PER_HOUR); //Calculate current Time Zone time by offset value
Year = year();
Month = month();
Day = day();
Hour = hour();
Minute = minute();
Second = second();
if (Hour < 10) Serial.print(F("0"));
Serial.print(Hour); //hour
Serial.print(F(":"));
if (Minute < 10) Serial.print(F("0"));
Serial.print(Minute); //minute
if (Second < 10) Serial.print(F("0"));
Serial.print(Second);
else
void TempSensor() //ambient temperature
val = analogRead(temPin);
delay(10);
mv = (val/1024.0)*5000;
cel = mv/10;
Serial.print(F(" TEMPERATURE = "));
Serial.print(cel); //temperature value in degree Celcius
Serial.print(F("*C"));
LCD.print("TEMP:");
LCD.print(cel,4);
delay(100);
//delay(10);
void PMSensor()
digitalWrite(ledPower, LOW); // power on the LED
delayMicroseconds(samplingTime);
voMeasured = analogRead(dustPin); // read the dust value
delay(10);
delayMicroseconds(deltaTime);
digitalWrite(ledPower, HIGH); // turn the LED off
delayMicroseconds(sleepTime);
// 0 - 5V mapped to 0 - 1023 integer values
// recover voltage
calcVoltage = voMeasured * (5.0 / 1024.0);
// linear eqaution taken from http://www.howmuchsnow.com/arduino/airquality/
// Chris Nafis (c) 2012
dustDensity = 0.17 * calcVoltage - 0.1;
/*Serial.print("Raw Signal Value (0-1023): ");
Serial.print(voMeasured);
Serial.print(" - Voltage: ");
Serial.print(calcVoltage);*/
Serial.print(" - Dust Density: ");
Serial.println(dustDensity,4); // unit: mg/m3
LCD.print("PM: ");
//LCD.clear();
delay(100);
//delay(10);
This is the code for the AlphaSensors:
int SN1_WE;
int SN1_Aux;
int SN2_WE;
int SN2_Aux;
int SN3_WE;
int SN3_Aux;
int Volt_PT;
int WE1Pin = 2;
int Aux1Pin = 3;
int WE2Pin = 4;
int Aux2Pin = 5;
int WE3Pin = 6;
int Aux3Pin = 7;
int PTPin = 1;
// formulas
float Temp_PT; // PT1000
float SN1_WE_Real; // NO2 WE
float SN1_Aux_Real; // NO2 Aux
float NO2; // NO2 ppb
float SN2_WE_Real; // CO WE
float SN2_Aux_Real; // CO Aux
float CO; // CO ppb
float SN3_WE_Real; // SO2 WE
float SN3_Aux_Real; // SO2 Aux
float SO2; // SO2 ppb
//Calibration Constants
// for SN1 or NO2
float SN1_TOTAL_WE = 0.1720;
float SN1_TOTAL_AE = 0.2240;
float SN1_SENSITIVITY = 0.2080;
// for SN2 or CO
float SN2_TOTAL_WE = 0.2880;
float SN2_TOTAL_AE = 0.2560;
float SN2_SENSITIVITY = 0.2630;
//for SN3 or SO2
float SN3_TOTAL_WE = 0.2630;
float SN3_TOTAL_AE = 0.2770;
float SN3_SENSITIVITY = 0.2970;
void setup ()
Serial.begin (9600);
void loop()
SN1_WE = analogRead(WE1Pin);
delay(10);
SN1_Aux = analogRead(Aux1Pin);
delay(10);
SN2_WE = analogRead(WE2Pin);
delay(10);
SN2_Aux = analogRead(Aux2Pin);
delay(10);
SN3_WE = analogRead(WE3Pin);
delay(10);
SN3_Aux = analogRead(Aux3Pin);
delay(10);
Volt_PT = analogRead(PTPin);
Temp_PT = 20 + ((Volt_PT - (0.297)*(0.3000))/(0.0010));
Serial.print("Temperature = ");
Serial.print(Temp_PT);
Serial.println();
if(Temp_PT <= 10)
SN1_WE_Real = SN1_WE - SN1_TOTAL_WE;
SN1_Aux_Real = 1.090*(SN1_Aux - SN1_TOTAL_AE);
NO2 = (SN1_WE_Real - SN1_Aux_Real)/(SN1_SENSITIVITY);
Serial.print("NO2 Voltage = ");
Serial.print(SN1_WE);
Serial.print(" V");
Serial.print(" ");
Serial.print(SN1_Aux);
Serial.print(" V");
Serial.print(" - NO2 CONCENTRATION = ");
Serial.print(NO2);
Serial.print(" ppb");
Serial.println();
SN2_WE_Real = SN2_WE - SN2_TOTAL_WE;
SN2_Aux_Real = 1.000*(SN2_Aux - SN2_TOTAL_AE);
CO = (SN2_WE_Real - SN2_Aux_Real)/(SN2_SENSITIVITY);
Serial.print("CO Voltage = ");
Serial.print(SN2_WE);
Serial.print(" V");
Serial.print(" ");
Serial.print(SN2_Aux);
Serial.print(" V");
Serial.print(" - CO CONCENTRATION = ");
Serial.print(CO);
Serial.println();
SN3_WE_Real = SN3_WE - SN3_TOTAL_WE;
SN3_Aux_Real = 1.1500*(SN3_Aux - SN3_TOTAL_AE);
SO2 = (SN3_WE_Real - SN3_Aux_Real)/(SN3_SENSITIVITY);
Serial.print("SO2 Voltage = ");
Serial.print(SN3_WE);
Serial.print(" V");
Serial.print(" ");
Serial.print(SN3_Aux);
Serial.print(" V");
Serial.print(" - SO2 CONCENTRATION = ");
Serial.print(SO2);
Serial.println();
if(Temp_PT >= 30)
SN1_Aux_Real = 3.000*(SN1_Aux - SN1_TOTAL_AE);
Serial.print(" V");
Serial.print(" ");
Serial.print(" V");
Serial.print(NO2);
Serial.println();
SN2_Aux_Real = -0.7600*(SN2_Aux - SN2_TOTAL_AE);
Serial.print(" V");
Serial.print(" ");
Serial.print(" V");
Serial.print(CO);
Serial.println();
SN3_Aux_Real = 3.9300*(SN3_Aux - SN3_TOTAL_AE);
Serial.print(" V");
Serial.print(" ");
Serial.print(" V");
Serial.print(SO2);
Serial.println();
else
SN1_Aux_Real = 1.3500*(SN1_Aux - SN1_TOTAL_AE);
Serial.print(" V");
Serial.print(" ");
Serial.print(" V");
Serial.print(NO2);
Serial.println();
SN2_Aux_Real = -1.000*(SN2_Aux - SN2_TOTAL_AE);
Serial.print(" V");
Serial.print(" ");
Serial.print(" V");
Serial.print(CO);
Serial.println();
SN3_Aux_Real = 1.8200*(SN3_Aux - SN3_TOTAL_AE);
Serial.print(" V");
Serial.print(" ");
Serial.print(" V");
Serial.print(SO2);
Serial.println();
delay(1000);
