High Current PCB Connectors
I’m designing a PC board with 10 3-amp H-bridges plus switching power subsystems.
I need a wire to board 2-pin connector that can handle at least 2 amps, and another that can handle at least 20. I have found some 3 amp bornier terminals, but I would prefer a solder type since the wires are harnessed and may move.
Any recommendations; anything under 2 bucks/piece are good.
I like using Anderson PowerPole connectors for this kind of application. They have some really nice (hefty) right angle contacts made for PCB mounting.
http://www.powerwerx.com/anderson-power … ntact.html
I have a library that I created in Eagle for using them. If you are using Eagle, I would be more than happy to send it to you.
