I am trying to measure the velocity of a high speed ping pong ball cannon. I have an old, beat up system that works but it needs updated due to wear and tear. The present velocity is 800m/s - well over Mach 2 so need FAST response time. I’ve used TSL252R sensors in the past, but they are no longer available. These SparkFun sensors look very close.
https://www.sparkfun.com/products/241
Rise/fall time is just a little slower than I would like. Does anyone know of any IR type break beam sensors with a faster response time??? I’ve ordered several that advertise a 7usec rise/fall time, but performance looks on the order of 70usec rise/fall time - not sure if they are counterfeit or just junk to begin with. I would even consider a more expensive type break-beam setup with faster response time if there’s one available. Laser???
I’ve also tried OP800A sensors but response was not anywhere near 7usec. FYI - going for world record attempt so want the best data possible.
