Hire a protyper
I have two projects I would like to just hire someone to prototype for me…
One involves a real-time pressure/humidity sensor going to a custom small display.
The other involves a specific musical tuner that can show tuning of 4 instruments in real-time.
Please let me know if you are interested.
see pm
Hi Stevech,
I need more info on pressure range type of sensor and accuracy wanted.What is the working temperature of yr system?
like to hear from you.
Best regards,
Pic buster
Picbuster:
Hi Stevech,
Best regards,
Pic buster
But… what are YOUR requirements?
My requirements?
Completely depending on your spec’s I might have something on the shelf.
Do you need one,ten or bulk?
To give you a impression one PCB 5 x 100 mm double side 4 layer PCB (no components just chemical work) 10 pcb’s
22 Euro each.
Work: 2-4 days depending on accuracy 10 bits needed or 24 bits stability 50ppm/Celsius or better
Component price: again depending on spec’s.
Power from PC USB? normal<= 5V 100mA. direct involved type of display and it’s power house holding.
As you can sees simple things could be difficult.
Best regards,
Picbuster
Picbuster, I really think you meant to quote 3DPiper’s post, not Steve’s…
Sorry,
Yes, correct.
I should polish my spectacles.
Regards,
picbuster
Doesn’t matter. OP is long gone.
