Just curious if there are plans to add the Hirose DF 50 70-pin connector to the SFE eagle public library on github?
It is listed on the Sparkfun Github, but is not in the default SF library. https://github.com/sparkfun/Sparkfun_Bl … r/Hardware
I have attached the library.
@Ross, thank you.
EDIT: Turns out that it is in the SPE library. Listed as EDISON_CONNECTOR_FULL and EDISON_CONNECTOR_SEGMENTED.
