Holes Not lining up...
I’m trying to generate Gerber files to get some boards made. Everything looks to be located at 0,0 when I run the CAM process, but when I open everything with Gerbv the holes are way off. I tried to measure the offset and then change the location for the holes in the CAM process. No dice.
What am I doing wrong here?
What PCB software?
Sorry, eagle 6.
I don;t use Eagle, but I found this in a few seconds:
http://www.eaglecentral.ca/forums/index … afafc60e83
Thanks, I didn’t even think of looking for a Eagle forum.
unchecking “pos coordinates” did the trick for me.
