Hello guys! I’m worknig for a new project… actually is a birthday present for a friend of mine…
As always please excuse my English… If I’m not wrong what I want to make is an “intercomunicator” (or something like that)… The idea is to build a device like a radio transmitter/receiver, so 2 people can talk to each other. The idea is to use it when traveling on a motorbike.
Well the problem is that I don’t know if I should use an AM or FM transmitter/receiver… Range is not a problem (50/100mts would be ok… or more) I want to power it with some battery (I preffer 1.5v or 3v but it could also be 9v. The problem with 9v-batteries is the mAh of them)
And above all, I don’t want (if possible) to mess around with inductor so I’d like the oscillator to be made of a cristal (or some easy PCB coil)
What I’m looking for is circuit schematic for the transmitter and the receiver… I guess they would be FM… but I don’t know wich one (AM or FM) is the best choice for my project.
Take a look at this circuit (click on green font to see the schematics): http://www.electronic-circuits-diagrams … ckt8.shtml
It says it would be working at 96.3Mhz… and the antenna could be an aerial of 1/4th wavelength (I guess lambda/4 of 96.3Mhz at speed of light, right?)
And is there an easy way to build a FM receiver without using any IC?
Thanks in advance!!! I would be very happy if I can sourprise my friend!
