Hi there,
I recently starting brewing home beer and it’s awesome.
I’m planning to go all-electric brewing and I saw some controller are for sale, but cost a lot. Having a friend that is in electronics, he told me I could pretty much do that as a way to learn electronics!
So here I am! I read a lot of tutorial on Sparkfun, ordered the art of electronics book and all.
Here is the high level description of what I want to accomplish.
The setup is as follow:
3 kettles - each with a temperature probe, 2 of them have a heating element as well.
2 pumps used to move liquid around the 3 kettles.
So the control box I want to build should be able to do the following:
Display actual temperature of the 3 kettles
Set the desired temperature for the 2 kettles with heating elements
Turn the heating elements ON automatically when the temperature is below the required temperature
A three-way switch to determine which of the 2 heating elements can be ON (or both elements to OFF)
Have a ON/OFF button for each pump
Have a timer that can be set and alert us when completed (sound made)
Display Volt/Amp/Watt comsumption
From what I understand right now, here are the high level step I think I will need to do:
Read the different datasheet to understand the requirement of each component (microcontroller, probe, display, etc)
Make a program that will let user interact with the display/buttons to set the desired temperature of the 2 kettle
Using different technique (voltage divider, capacitor, etc), connect my probe to the ADC of my microcontroller to read actual temperature
Depending on temperature vs desired temperature, turn ON the heating elements
Wire the ON/OFF switch of the pump so when on ON, the pump actually pumps something
I’m I on the right track?
