Hi there!
I’m working on a project where I have multiple functions in different voids, where I’m using a “menu” with help of two buttons (sw3 and sw4 in code) to change a value, and a start button (sw1) to change to another void. So far I have 6 voids that has different delays, before it goes to another void and back to the menu.
The main components is a Arduino pro, 2004 lcd display from ebay, 2x2 button pad from sparkfun and different leds and relays.
What I would like to do, is use another switch (sw2 in code) to abort the delay, and take it back to the menu.
I have found out that the arduino can’t do anything else during a delay. I have tried a for(); loop, just to test it out, with no luck. Tried millis(); too, but no matter how mutch I read about millis();, I still don’t understand how I can inplant that to my code.
In the code below, it is in void program1(); to program6(); I need help with.
Anyone on the forum that can explain the millis(); function for me and maybe help me out with inplant it in my code? Or do I have to find something else than millis();?
Here is my code:
#include <Wire.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(14,15,16,17,18,19);
// (RS, EN, DB4, DB5, DB6, DB7)
//Defining pins for switches
const int sw1 = 2; //Start button
const int sw2 = 3; //Stop button
const int sw3 = 4; //Prog - button
const int sw4 = 5; //Prog + button
//Defining pins for LEDs in switches
const int led1 = 6; //Start button LED
const int led2 = 7; //Stop button LED
const int led3 = 8; //Prog - button LED
const int led4 = 9; //Prog + button LED
//Defining pins for output LEDs
const int relayG = 10; //Relay for green light
const int relayY = 11; //Relay for yellow light
const int relayR = 12; //Relay for red light
//Defining value for program selection
int value;
void setup() {
//Defining pinMode's
pinMode(sw1, INPUT);
pinMode(sw2, INPUT);
pinMode(sw3, INPUT);
pinMode(sw4, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(relayG, OUTPUT);
pinMode(relayY, OUTPUT);
pinMode(relayR, OUTPUT);
//Starting a lamp test
lcd.begin(20, 4);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Lamp test");
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(relayG, LOW);
digitalWrite(relayY, LOW);
digitalWrite(relayR, LOW);
delay(10000);
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
digitalWrite(led3, HIGH);
digitalWrite(led4, HIGH);
digitalWrite(relayG, HIGH);
digitalWrite(relayY, HIGH);
digitalWrite(relayR, HIGH);
lcd.setCursor(0,1);
lcd.print("complete!");
delay(2000);
lcd.clear();
//Lamp test complete
//Setting value for program selection
value = 1;
//Turning red light on
//Is the people ready to open FIRE?!? This part is NOT complete yet
void er_skytter_klar() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Er skytterene klare?");
lcd.setCursor(0,1);
lcd.print("Hvis nei, trykk rød");
lcd.setCursor(0,2);
lcd.print("knapp innen 15");
lcd.setCursor(0,3);
lcd.print("sekunder");
if (digitalRead(sw2) == HIGH) {
avbryt();
} else if (digitalRead(sw2) == LOW ) {
//Program 1, 6 sec
void program1() {
delay(100);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 1 kjorer");
lcd.setCursor(0,1);
lcd.print("6 sekunder");
lcd.setCursor(0,2);
lcd.print("skyting");
delay(4000);
stans();
//Program 2, 8 sec
void program2() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 2 kjorer");
lcd.setCursor(0,1);
lcd.print("8 sekunder");
lcd.setCursor(0,2);
delay(6000);
stans();
//Program 3, 10 sec
void program3() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 3 kjorer");
lcd.setCursor(0,1);
lcd.print("10 sekunder");
lcd.setCursor(0,2);
delay(8000);
stans();
//Program 4, 20 sec
void program4() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 4 kjorer");
lcd.setCursor(0,1);
lcd.print("20 sekunder");
lcd.setCursor(0,2);
delay(18000);
stans();
//Program 5, 120 sec
void program5() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 5 kjorer");
lcd.setCursor(0,1);
lcd.print("120 sekunder");
lcd.setCursor(0,2);
delay(118000);
stans();
//Program 6 300 sec
void program6() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 6 kjorer");
lcd.setCursor(0,1);
lcd.print("300 sekunder");
lcd.setCursor(0,2);
delay(298000);
stans();
//Program 7, ∞ sec
void program7() {
stans();
} else {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Program 7 kjorer");
lcd.setCursor(0,1);
lcd.print("Friskyting");
delay(200);
program7();
//Stop sequense
void stans() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Staaaaaaaaaaaaaaaans");
delay(2000);
performCommand();
//Abort sequense
void avbryt() {
performCommand();
//Lamp test
void lamptest() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Lampe test");
delay(10000);
lcd.setCursor(0,1);
delay(2000);
performCommand();
//Program selector
void performCommand() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Lismarken pk");
lcd.setCursor(0,1);
lcd.print("Velg program:");
lcd.setCursor(0,2);
lcd.print("Program:");
lcd.setCursor(10,2);
lcd.print(value);
//Magic that changes value with buttons!
if (digitalRead(sw3) == HIGH) {
value--;
delay(350);
if (value == 0) value = 8;
if (digitalRead(sw4) == HIGH) {
value++;
delay(350);
if (value == 9) value = 1;
//Showing text on line 4 on lcd, according to withc program to be selected
if (value == 1) {
lcd.setCursor(0,3);
lcd.print("6 sekunder skyting");
} else if (value == 2) {
lcd.setCursor(0,3);
lcd.print("8 sekunder skyting");
} else if (value == 3) {
lcd.setCursor(0,3);
lcd.print("10 sekunder skyting");
} else if (value == 4) {
lcd.setCursor(0,3);
lcd.print("20 sekunder skyting");
} else if (value == 5) {
lcd.setCursor(0,3);
lcd.print("120 sekunder skyting");
} else if (value == 6) {
lcd.setCursor(0,3);
lcd.print("300 sekunder skyting");
} else if (value == 7) {
lcd.setCursor(0,3);
} else if (value == 8) {
lcd.setCursor(0,3);
//This makes the hole shit go in a loop, untill start button is pressed
if (value == 1 && digitalRead(sw1) == HIGH) {
program1();
} else if (value == 2 && digitalRead(sw1) == HIGH) {
program2();
} else if (value == 3 && digitalRead(sw1) == HIGH) {
program3();
} else if (value == 4 && digitalRead(sw1) == HIGH) {
program4();
} else if (value == 5 && digitalRead(sw1) == HIGH) {
program5();
} else if (value == 6 && digitalRead(sw1) == HIGH) {
program6();
} else if (value == 7 && digitalRead(sw1) == HIGH) {
program7 ();
} else if (value == 8 && digitalRead(sw1) == HIGH) {
lamptest ();
delay(200);
void loop() {
performCommand();
