x-ray
1
Hi!
i have ARM JTAG from Olimex.
when i debugging with JTAG to my board (LPC2138), it’s worked.
but when i release JTAG from my PC, the code it’s not working.
it’s JTAG only for debugging and must connect with my PC to make it worked?
how can i make my code running even i released my JTAG?
thx.
May be your board enters the ISP mode after reset, probably there is a jumper to make it boot on the user code.
It depends on the tools you are using.
Leon
x-ray
4
leon_heller:
Leon
i’m using OLIMEX LPC2138 and Rowley Crosswork…
It’s in the Rowley FAQs on their web site. You need STARTUP_FROM_RESET.
Leon
x-ray
6
leon_heller:
Leon
did you mean the startupcode->properties->predifinition preprocessor? it’s already STARTUP_FROM_RESET.
but still can’t work, if i released JTAG…
Make sure you added it to the correct file.
Look at the notes in the FAQ, they might help with troubleshooting.
Leon
I´ve got exactly the same problem, x-ray, do you, or enyone else, have found the problem?
