How to run code through ucLinux
Hello everyone,
We’re just getting started with the lpc2478-STK and we were able to install uCLinux and compile code for it (using the make command). However, to send the file to the processor, we used the loady command prior to going to ucLinux. Once the file has been loaded, how do we run it using ucLinux?
Thank you very much!
Hai,
I am also working on LPC2478STK with uclinux compilation. So can you please share the uclinux and UBOOT supported files for LPC2478STK
Thanks & Regards
Siva Krishna.
