How to update Lilypad MP3 with VS1053B firmware ?
I need to update this chipset incluided in the Lilypad MP3 of Sparkfun
I have an .ino, but how I can apply the update?
http://www.vlsi.fi/en/support/software/ … tches.html
Sparkfun’s technical service has not wanted me or knows how to tell me how to do it and the manufacturer has responded. But, given my limited knowledge, I still do not know how to apply this firmware that has very important improvements
I hit here the answer given by the manufacturer:
"There is no programmable non-volatile memory in vs1053b. There is only ROM and RAM.
Patch code is thus loaded (through the serial control interface) after each power-up or reset. If the Lilypad already supports loading patches, there is probably a file vs1053b-patches.plg (or vs1053b-patches.c) somewhere in its firmware project. You should only need to replace the file with a newer version.
(If not, then see the upload routine in the file itself (e.g. vs1053b-patches.plg). It only needs an external SCI register write function. Also see the microcontroller examples elsewhere in the forum.)"
So, how do we update the Lilypad MP3?
Best regards!
