Hello , everyone! Recently I’ve bought the arduino board with the arduino breadboard syb 46 https://drive.google.com/file/d/0B4BDjp … sp=sharing.
The problem is I don’t understand how to use it. I can’t understand the scheme of this model of breadboard, where is plus and minus, where is ground , etc. I’ve already watched a lot videos about arduino breadboards on youtube but I found no videos about this arduino breadboard model
I 'm asking about help, because the absence of needed information very frustrates me
so I can’t begin to work on arduino
Thanks in advance!
It looks to me to be a common solderless breadboard.
https://learn.sparkfun.com/tutorials/ho … breadboard
Am I missing something obvious ?
It seems to me that you’re missing the fact that the commonly used breadboards have two power rails . For example, in the post you shared me we can see a breadboard with two power rails
But my breadboard has just one power rail.
That confuses me extremely
vyacheslav_serkov:
That board has 4 rails, 2 on each side.
That board has 2 rails, one on each side.
Is that so hard to figure out
Secondly, why would you buy a board that confuses you?
vyacheslav_serkov:
Well it still works the same as the other one, just with less access to it's "power" rails. Given that a lot of circuits only use 1 supply voltage and ground, it's not that limiting. But if you have a circuit that needs multiple voltages either get a BB with multiple rails or dedicate an unused row (or 2) to be a power "rail". Then the wires just go to a different physical location.
