Hello.
I’d like to connect to i.MX27ADS by OpenOCD.
However, I’ve not succeeded yet.
advice me, plz.
log list is below
Debug: 15 15 command.c:430 command_run_line(): jtag_device 4 0x1 0xf 0x2
Debug: 16 16 command.c:430 command_run_line(): jtag_device 4 0xf 0xf 0xe
Debug: 17 18 command.c:430 command_run_line(): jtag_nsrst_delay 20
Debug: 18 19 command.c:430 command_run_line(): jtag_ntrst_delay 20
Debug: 19 20 command.c:430 command_run_line(): daemon_startup attach
Info: 20 21 options.c:50 configuration_output_handler(): Open On-Chip Debugger 1.0 (2008-06-01-02:15) svn:696
Debug: 21 22 command.c:430 command_run_line(): target arm926ejs little run_and_halt 0 arm926ejs
Debug: 22 23 arm926ejs.c:733 arm926ejs_target_command(): chain_pos: 0, variant: arm926ejs
Info: 39 591 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x1b900f0f
(Manufacturer: 0x787, Part: 0xb900, Version: 0x1)
Info: 40 593 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07926121
(Manufacturer: 0x090, Part: 0x7926, Version: 0x0)
Debug: 41 594 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG control
ler reset(tms or TRST)
Debug: 42 595 jtag.c:1295 jtag_reset_callback(): -
Debug: 43 596 jtag.c:1295 jtag_reset_callback(): -
Debug: 44 791 openocd.c:116 handle_init_command(): jtag init complete
Error: 45 990 embeddedice.c:191 embeddedice_build_reg_cache(): unknown EmbeddedICE version (comms ctrl: 0x00000000)
and my configuration file is this.
interface ft2232
ft2232_device_desc "TINY JTAG-ICE A"
ft2232_layout jtagkey
ft2232_latency 1200
jtag_speed 0
#jtag_khz 30
#reset_config trst_and_srst
reset_config trst_only
#reset_config srst_only
jtag_device 4 0x1 0x1 0xe
jtag_device 4 0x1 0xf 0xe
jtag_nsrst_delay 20
jtag_ntrst_delay 20
run_and_halt_time 0 30
