Hello my dear friends.My project consist of 2 servo 2 dc motors and 3 ultrasonic sensors.Before i added servo motor codes,my system was working smootly.But now,since i added my servo motor codes and cases,my circuit is working wrong.I mean only one servo and one dc motor is working at the same time.Can you guys PLS help to find my error .Thank you…
#include<Servo.h>
Servo servo1;
Servo servo2;
int pos=0;
// ön
const int triger_pin =2;
const int echo_pin=3;
//sağ
int triger_pin2 =4 ;
int echo_pin2 = 5;
//sol
int triger_pin3 =6;
int echo_pin3 = 7;
const int sag_i=8;
const int sag_g=9;
const int sol_i=12;
const int sol_g=13;
int sure1;
int mesafe1;
int sure2;
int mesafe2;
int sure3;
int mesafe3;
// motor 1
int enA = 10; /* Enable girişleri Arduinonun pwm girişlerine bağladık.*/
// motor 2
int enB = 11; /* Enable girişleri Arduinonun pwm girişlerine bağladık.*/
void setup() {
servo1.attach(A2);
servo2.attach(A3);
digitalWrite(A2,HIGH);
digitalWrite(A3,HIGH);
Serial.begin (9600);
pinMode(triger_pin, OUTPUT);
pinMode(echo_pin, INPUT);
pinMode(triger_pin2, OUTPUT);
pinMode(echo_pin2, INPUT);
pinMode(triger_pin3, OUTPUT);
pinMode(echo_pin3, INPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
void loop() {
/-------------------------Servo Motorlar-----------------------/
for(pos=0;pos<=180 ; pos+=11)
servo1.write(pos);
servo2.write(pos);
delay(15);
for(pos=180;pos>=0 ; pos-=11 )
servo1.write(pos);
servo2.write(pos);
delay(15);
/* ----------------Ön Sensör----------------------*/
digitalWrite (triger_pin, HIGH);
delayMicroseconds (1000);
digitalWrite (triger_pin, LOW);
sure1 = pulseIn (echo_pin, HIGH);
mesafe1 = (sure1/2) / 29.1;
Serial.print(“On sensor:”);
Serial.print(mesafe1);
Serial.print(“cm”);
Serial.println();
/-----------------Sag Sensör-----------------------/
digitalWrite (triger_pin2, HIGH);
digitalWrite (triger_pin2, LOW);
sure2 = pulseIn (echo_pin2, HIGH);
mesafe2 = (sure2/2) / 29.1;
Serial.print(“Sag sensor:”);
Serial.print(mesafe2);
Serial.print(“cm”);
Serial.println();
/-----------------Sol Sensör-----------------------/
digitalWrite (triger_pin3, HIGH);
digitalWrite (triger_pin3, LOW);
sure3 = pulseIn (echo_pin3, HIGH);
mesafe3 = (sure3/2) / 29.1;
Serial.print(“Sol sensor:”);
Serial.print(mesafe3);
Serial.print(“cm”);
Serial.println();
// Motorlar sabit hızda aynı yöne dönüyorlar.
// sol motor ileri
digitalWrite(sag_i, HIGH);
digitalWrite(sag_g, LOW);
// Motor 1 için 0~255 arasında bir hız değeri verelim. 255 en üst sınır
analogWrite(enA, 75);
// sağ motor ileri
digitalWrite(sol_i, HIGH);
digitalWrite(sol_g, LOW);
// Motor 2 için 0~255 arasında bir hız değeri verelim. 255 en üst sınır
analogWrite(enB, 75);
if(mesafe1<30 )//ön sensör
//motorlar durduruluyor
digitalWrite(sag_i, LOW);
digitalWrite(sol_i, LOW);
delay(500);//bir üst fonksiyonun çalışma süresi
// motorlar geriye dönüyor
digitalWrite(sag_g, HIGH);
digitalWrite(sol_g, HIGH);
digitalWrite(sol_g, HIGH );
delay(1000);//bir üst fonksiyonun çalışma süresi
if(mesafe2<7 )//sağ sensör
//sağ motor
analogWrite(enA,75);
//sol motor
analogWrite(enB,75);
delay(500);
if(mesafe3<7 )//sol sensör
//sağ motor
//sol motor
delay(500);
