good morning everyone
I use the board in olimex with the LPC2478, but I have a problem I didn’t arrived to use the usb host (new for me),
would you someone in this forum, who has managed to transfer data between a LPC2478 and memory stick .
I am using IAR Embedded and not kiel
it is really important to me and I hope you can help me.
Thank you
There is a fully working example in the IAR EWB examples folder. I’ve modified this to load bitmap images from the USB stick to the LCD - works fine.
thank you for your answer but where will be able I to find this example, using the bus usb.
I know that there are requetes of addressing and of description but I am not able to bring them into service,
if you indicated the bond where I will be able can find this example or same by kindness to be sent on my email your program (I want just a transfer of data, I will not touch has your program I will remake mine but by helping me of the tien because I am null in programming)
thank you in advance, and I espere that you will be able helped me.
Antoine
Have you looked in the EWB Examples folder?
Leon
will have you a bond has to pass to me thank you
Antoine
FZ1 yamaha
thanks for your post but i have find how send data
i have just some probleme with regisrte, now it’s oki
thanks
