Is it possible to change the I2C address of a MS5637 Pressure Sensor on a SPX-14688 board so that two sensors can be read on a single I2C line?
Hi Griff.
Unfortunately I’m not seeing anything in the datasheet that leads me to believe the address is changeable on these.
What you’d probably want to do is connect both of them to your system through a MUX like the [Qwiic Mux Breakout. That would allow you to switch between the two sensors and potentially add 6 more if you needed too.](https://www.sparkfun.com/products/14685)
