Please can you help explain how I connect I2C across the Single Supply Logic Level Converter?
I’m trying to connect a 3.3V SparkFun LoRa Thing Plus - expLoRaBLE to a 5V analogue sensor connected to 2 ADCs.
The ADCs both have separate I2C addresses configured but neither are responding.
I’ve connected the following:
VIN:
3.3V - 3-5.5V
GND - GND
SDA - A1
SCL - A2
VOUT:
5V - 5V
GND - GND
SDA - B1
SCL - B2
Unfortunately, I’ve already soldered it up - doh… this was largely because the analogue sensor connects by ribbon wire which i couldn’t connect to a breadboard. Anyhow - I can’t test connection changes easily so hoping someone knows what to do!
