Hi everyone,
I am very new to FPGA development and could use some help trying to figure out what is going wrong with my I2C code I’ve written to communicate with the magnetometer.
My issue is that I seem to be able to write to the configuration registers (first image) but I am only getting zeros from the data registers (second image). I even compared my results with what I was seeing with a logic analyzer when the sensor was hooked up to an Arduino and tried to match the protocol as closely as I could. I understand that the sensor sends zeros when attempting to read an invalid address but 0x03 should be valid. I have attached my code (I apologize it’s probably quite messy) and some images of what’s happening.
Another issue I’m having is that if change the orientation of the chip to flat on the table, SDA drops low and I don’t see anything happening anymore (fourth image). Am I missing some kind of necessary calibration?
http://i.imgur.com/wAqOUP4.png?2
http://i.imgur.com/fSxw1xr.png?1
http://i.imgur.com/HaDLjae.png?2
// Company: University of Colorado
// File: i2c_interface2.v
// Description:
// I2C interface with sparkfun hmc5883l magnetometer breakout
// Targeted device: <Family::ProASIC3L> <Die::M1A3P1000L> <Package::484 FBGA>
// Author:
module i2c_interface2(
input clk,
input rst,
//input byte_to_mag,
input [23:0] timestamp,
inout sda,
output scl,
output [79:0] data,
output state
localparam IDLE = 4'ha,
START = 4'h1,
ADDR = 4'h2,
RW = 4'h3,
ACK_IN = 4'h4,
ACK_OUT = 4'h5,
INIT = 4'h6,
DATA = 4'h7,
STOP = 4'h8,
WAIT = 4'h9,
DATA_POINTER = 4'hb,
STARTUP = 4'h0;
localparam M = 8'h4d;
localparam reg0_addr = 8'h0/*8'b11010101*/, //Testing value
reg0_val = 8'h0c,
reg1_addr = 8'h1,
reg1_val = 8'h0,
reg2_addr = 8'h2,
reg2_val = 8'h0,
reg3_addr = 8'h3,
addr = 7'h1e,
six = 8'h6;
reg [16:0] wait_ctr;
reg [7:0] state_a, state_hold,test;
reg begin_data;
reg [47:0] data_a, data_out;
reg sda_a, stop_enable, init, start_ctr, scl_enable;
reg [3:0] ctr_a, init_ctr_a, data_cntr;
reg test_sda, force_reset;
reg [1:0] data_mode;
assign scl = ((clk) | (state_a == IDLE) | (state_a == STOP) | (scl_enable == 1'b0) | (state_a == STARTUP)) & (state_a != WAIT); //high during idle/stop, pulls low on start and active high pulses
assign sda =(state_a != ACK_IN)&(state_a != DATA) ? sda_a : 1'bz; //Sets whether sda is in or out
assign data = {data_out,timestamp,M};
assign state = !((state_a != ACK_IN)&(state_a != DATA));
always @(negedge clk or negedge rst) begin //Ensures clock is low when sda changes
if ((rst == 1'b0)|| force_reset) begin
state_a = STARTUP;
sda_a = 1'b1;
ctr_a = 4'd0;
begin_data = 1'b0;
init_ctr_a = 4'd6;
stop_enable = 1'b0;
data_a = 48'b0;
init = 1'b0;
start_ctr = 1'b0;
data_cntr = 4'd0;
test = 8'd0;
data_out = 48'b0;
data_mode = 2'd0;
wait_ctr = 17'd0;
scl_enable = 1'b0;
state_hold = 4'ha;
force_reset = 1'b0;
end
else if (!clk) begin
test_sda = !((state_a != ACK_IN)&(state_a != DATA));
case(state_a)
STARTUP: begin
if (wait_ctr >= 100000) begin
state_a = IDLE;
wait_ctr = 0;
end
else wait_ctr = wait_ctr + 1;
end
IDLE: begin
scl_enable = 1'b0;
ctr_a = 7'd0;
sda_a = 1'b1;
start_ctr = 1'b0;
test = 1;
if ((wait_ctr >= 13340)|| ~init || (data_mode == 2'd0)) begin
state_a = START;
wait_ctr = 0;
end
if ((wait_ctr >= 2) && (sda == 1'b0)) begin
force_reset = 1'b1;
end
end
START: begin
if ((start_ctr == 1'b0)&&(sda == 1'b1)) begin
start_ctr = 1'b1;
sda_a = 1'b0;
test = 2;
//scl_enable = 1'b0;
end
else if (start_ctr == 1'b1 && sda == 1'b0) begin
start_ctr = 1'b0;
state_a = ADDR;
ctr_a = 7;
test = 3;
end
end
ADDR: begin
if (ctr_a != 0) begin
test = 5;
scl_enable = 1'b1;
sda_a = addr[ctr_a-1];
ctr_a = ctr_a-1;
end
else begin
state_a = RW;
if (~init & (data_mode == 2'd0)) begin
sda_a = 1'b0;
state_hold = INIT;
end
else begin
if (data_mode == 2'd1) begin
state_hold = DATA;
sda_a = 1'b1;
end
else if (data_mode == 2'd0) begin
sda_a = 1'b0;
state_hold = DATA_POINTER;
end
end
end
end
RW: begin //low is write, high is read & low ACK is confirm.
scl_enable = 1'b1;
test = 6;
sda_a = 1'b0;
state_a = ACK_IN;
end
ACK_IN: begin //look for slave ACK
test = 7;
if (~sda) begin
if (~init) begin
if (state_hold == STOP) begin
sda_a = 1'b0;
state_a = WAIT;
scl_enable = 1'b0;
end
else begin
sda_a = 1'b0;
state_a = WAIT;
scl_enable = 1'b1;
end
end
if (init) begin
if (state_hold == START) sda_a = 1'b1;
else sda_a = 1'b0;
if (data_cntr == 4'd0) data_cntr = 4'd5;
state_a = WAIT;
end
end
else begin // If there's a NACK, stop and go back
state_a = WAIT;
state_hold = STOP;
scl_enable = 1'b0;
sda_a = 1'b0;
if (init) data_cntr = data_cntr + 1;
else init_ctr_a = init_ctr_a + 1;
end
end
ACK_OUT: begin //send ACK to slave
sda_a = 1'b0;
if (data_cntr == 0) begin
state_a = WAIT;
state_hold = STOP;
scl_enable = 1'b0;
end
else begin
state_a = WAIT;
ctr_a = 7;
end
end
INIT: begin //write to registers
test = 8;
scl_enable = 1'b1;
if (ctr_a == 0) begin
test = 14;
state_a = ACK_IN;
sda_a = 0;
if (init_ctr_a !=0) begin
init_ctr_a = init_ctr_a - 1;
end
end
else begin
if (init_ctr_a == 2) begin
test = 9;
sda_a = reg0_addr[ctr_a-1];
end
else if (init_ctr_a == 1) begin
test = 10;
sda_a = reg0_val[ctr_a-1];
state_hold = STOP;
end
else if (init_ctr_a == 4) begin
test = 11;
sda_a = reg1_addr[ctr_a-1];
end
else if (init_ctr_a ==3) begin
test = 11;
sda_a = reg1_val[ctr_a-1];
state_hold = STOP;
end
else if (init_ctr_a == 6) begin
test = 11;
sda_a = reg2_addr[ctr_a-1];
end
else if (init_ctr_a == 5) begin
test = 12;
sda_a = reg2_val[ctr_a-1];
state_hold = STOP;
end
end
if (ctr_a != 0) ctr_a = ctr_a - 1;
end
DATA_POINTER: begin
if (data_mode == 0) begin
state_a = ACK_IN;
state_hold = STOP;
data_mode = 2'd1;
end
else ctr_a = ctr_a - 1;
sda_a = reg3_addr[ctr_a];
end
end
DATA: begin //read data
scl_enable = 1'b1;
state_a = ACK_OUT;
stop_enable = 1'b1; ///set low after stop mode
data_out = data_a; // data's ready to go to memory
data_mode = 2'd0;
end
end
else begin
data_a[ctr_a+data_cntr*8] = sda;
ctr_a = ctr_a - 1;
end
//end
end
STOP: begin //initiate stop condition
stop_enable = 1'b0;
sda_a = 1'b1;
state_a = IDLE;
scl_enable = 1'b0;
if (data_cntr == 0) data_cntr = 6;
sda_a = 1'b0;
end
WAIT: begin //waits clk period for next cycle
test = 15;
state_a = state_hold;
if (~init) begin
sda_a = reg0_addr[7];
ctr_a = 7;
end
sda_a = reg0_val[7];
ctr_a = 7;
end
sda_a = reg1_addr[7];
ctr_a = 7;
end
else if (init_ctr_a == 3) begin
sda_a = reg1_val[7];
ctr_a = 7;
end
sda_a = reg2_addr[7];
ctr_a = 7;
end
sda_a = reg2_val[7];
ctr_a = 7;
end
else if (init_ctr_a == 0) begin
init = 1'b1;
ctr_a = 7;
//sda_a = 1'b0;
end
end
else begin
ctr_a = 7;
scl_enable = 1'b0;
sda_a = 1'b0;
end
else if (data_mode == 2'd1 && (state_hold == DATA)) data_cntr = data_cntr - 1;
end
end
endcase
end
end
endmodule
