i2s DAC Audio Breakout (Intel Edison)
It would be rad if you folks made a board that provided terminals for stereo or mono audio input and output.
FYI,
There is a pcb available through [OHSpark. It is advertised as being compatible with the Edison blocks from Sparkfun.
There is the [link to the blog to build the yocto image.
I made one. It works. But I warn you the Hirose connectors are a pain to solder by hand.
B.R.
Tontome](http://www.malinov.com/Home/sergeys-projects/audio-block-for-intel-edison)](OSH Park ~)
