I²C ok
hi
i has finished my code and has just tested it
I use port I2C to write and to read a eeprom 24C32.
reading and the writing can be made on any page memory its works fine. if someone needs it!
on the other hand I wants to use the RTC, somebody already made?
I puts the battery of maintenance on which pin ??
some code??
i’m using LPC2129
thanks
It is great. Why don’t you open your code. Just share the knowledge.
hi
I need you code about i2c can you give me the file i2c.h and i2c.c
you can send me the file in my email adress: cavalierdelanuit@hotmail.com
thnaks
