If the reset capacitor was polarised (directional) what way should it point if it would work?
Could it cause probelms if it was not non-polorised?
What kind of resistance could be in series with it and still have it work properly?
Firstly, its +ve terminal should obviously be connected to Reset pin. and -ve to ground. A pull up resistor from Rest pin to Vdd is obvious.josheeg:
If the reset capacitor was polarised (directional) what way should it point if it would work?Could it cause probelms if it was not non-polorised?
Non polarised should behave much better but it might be bulky and costly.
