does anyon e know how I can make an if-then statement using the IAR Kickstart. Also does anyone know how to make one reading an input with or wothout reading an input. Thank you.
void main(){
/t // your initialisation code goes here
while(1){
if(something){
// your code here
else{
// your code here
Hello!
For your info and since you are using IAR, there is a bunche of sample
code on Texas Instruments’ homepage.
If I recall well, it was number 15, therefore slak0015k.zip (or maybe
with only 1 zero in the name).
You will find everything and even more for what you want to do.
As for your question itself, I think it might be a good to begin with a good
C reference book. And second advice, if you could really READ that book
and not simply copy the examples and execute them, you would learn
really fast. I know, I learned the slow way by copying code, executing,
spending hours to try to understan what was wrong…
Pascal
