Hello. I have a problem with WiFly. if the Internet fails my system does not work, that is, if there is no internet and I turn on Arduino-WiFly my program does not run! Is there any solution for this? I want that even without the Internet, my program run. With the example of library WiFly is possible to verify this. Thanks for your attention.
ROP,
If you want help here, you’re going to have to do a much better job of asking your question. I suggest you start by reviewing [this.
