Imu BNO086
I run an IMU BNO086.
Within a minute the yaw differs once ±150degres.
I use the example Geomagnetic to Euler out of the sparkfun library.
I need the heading info. Is this known or is the imu damaged?
Please advise.
Bernhard Graf
Most likely, the magnetometer is not properly calibrated. Magnetometers do not work “out of the box” as compasses.
Check the documentation for that particular IMU regarding calibration procedures: https://www.mouser.com/pdfDocs/BNO080-BNO085-Sesnor-Calibration-Procedure.pdf
Thanks for the information!
I have 055 and 085 of Adafruit in use and also some sparkfun RTK and IMUs. For the 086 I did the calibration accordingly and put in the setup parts of example 20 calibration.
When i operate my mobile robot with 086 it seens that the orientation is ok, but suddenly the 086 delivers a single wrong yaw.
What can this be?
Talking with you I know you are a friend of the ICM 20948, but there activating the dmp in line 29 is confusing. Can you explain me what to do for activating dmp?
Thanks a lot and have agreat day!
Mit freundlichem Gruß
Dr. Bernhard Graf
Mobil 01713610219
Unfortunately the automatic magnetometer calibration in the Bosch IMU sensors does not work very well.
Also, notice that the documentation warns you to turn off the calibration during game play, because it can cause a sudden orientation reset.
Sorry, I don’t use the DMP in the ICM-20948 – never bothered to study it.
