Indoor Air Quality Sensor / Controller
I would like to use sparkfun CO2 and Particulate sensors to control an ERV ventillation unit. I don’t have the coding skills. It seems the hardware is avaiable. Does anyone know who I can get to make this for me?
See if somebody responds here. If not, you can hire someone from the freelancing platforms. If you wanna give it a try, you have to use an Arduino/ESP32/Raspberry Pi to read Sparkfun CO2 and Particulate sensors. You will need a relay to control the ERV unit.
Here is how you can interface a relay module with an Arduino:
For coding, you will need to install the following libraries to get the sensors working.
You can fumble through a lot of it with iterating and feeding back errors to AI models online, or like mentioned above you can hire someone from a website like fiverr or upwork to knock it out for you
