Hi every one,
I’m a new beginner and I have a project in my mind… if it’s done already and I’m making a repost or saying something really unlogical… A big sorry in advance…
Okey about my project…
So I have this opel vauxhall saturn / astra h mk5 what ever it’s name over there :)… and I have bid screen
http://www.diagnostics.org.uk/wp-conten … bc-yes.jpg
I want to change this screen to a LCD one but rather than just ordering and LCD screen connecting it to dash and loose every function of this display I want to have these functions and have a LCD screen too…
While I was wondering in google writing hoplessly key words I see ardiuno box on my desk and I found my self reading these discussions and looking to products of the sparkfun :)…
So my big question is will it work ? You may directly say “why not??” but I have some questions and if you can answer them I will be much appriciated…
Here they are:
What I understand from my reading I have to get ardiuno(check) and can-bus shield(need to buy) right?
I do not want to use obd-2 port I want to use orginal wiring of the current screen (Where is my haynes manual) so if I can connect canl and canb of this wiring loom will it be enough?
If get it correctly to create visiual output first I have to read every signal for every function and define them and code them to my interface. So how can I understand what I’m reading from signals ??
In these cars sterio send password to screen or screen send password to the sterio for protection. I have the code so that is not the issue the issue is how can I make same password comunication between sterio and arduino unit?
Can arduino readings may cause damage any damage to ECU or any unit realted ?
Sorry for the English
and thanks…
