I am working on a very modified version of an example ESP32 to ESP32 WiFi from RandomNerds.
Converting the code to use SFE BME280 code was easy. It is the Server and WiFi AP. On the MicroMod I have an ESP32 client. Converting the code from the Adafruit Micro OLED to HyperDisplay took time but it works full screen.
I also got it to work split screen but I do not know how to blank just one window. I tried to refill the window (myTFT.fillWindow()
like I did at the creation of the window but it turns black and the program stops.
As all I really need is to blank out the old values I tried printing blank spaces but that didn’t do anything.
So is there any way to clear just one window?
Dale
ps I figured out how to use #define to create colors (I have a file converted from an Org file of several hundred color names and numbers). I have also figured out an easy way to print on the lines I want with the stock font.
