IOT Data Logger boards with >2 separate loadcells NAU7802
I have a a question concerning an IOT data logger board or similiar in connection with QWIIC loadcell NAU7802:
1.) Since from my understanding the QWIIC uses I2C can you connect 4 separate NAU7802 boards and read/calibrate each one separately from a separate address? Is there a limit to how many of the same devices can be added due to having the same address? Or would you need another module like an I2C expansion?
You can give them virtual addresses and use up to 8 by using https://www.sparkfun.com/products/16784
Be sure to disable the i2c pull-up resistors on all but one device (including the mux), and also note the max cable length (would be combined in this scenario) is usually about 0.5m for qwiic
