IR Custom Remote
Hello, So I am trying to develop a custom IR remote for a Lasko space heater I have. It already has a remote but I wanted to make a custom one with arduino. The first step I did was created an IR receiving sketch to capture the RAW codes from the remote I have right now.
#include <ir_Lego_PF_BitStreamEncoder.h>
#include <boarddefs.h>
#include <IRremoteInt.h>
#include <IRremote.h>
// If one keypress results in multiple codes being output, then
// change in IRremoteInt.h:
// #define _GAP 50000
// This sketchThis sketch was obtained from:
//  For more info:
//  jason welsh
//   https://www.youtube.com/watch?v=eR8sQq3pl20
//  https://docs.google.com/document/d/1QgmFbFlB0aI3swrhQkacRe3C-cIS0p1t0TV36-i2lLo/edit
//   http://www.instructables.com/id/Arduino-Remote-Control-Less-10/?ALLSTEPS
//  I made a few small changes
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600);
  irrecv.enableIRIn(); // Start the receiver
int c = 0;
void dump(decode_results *results) {
  int count = results->rawlen;
  Serial.println(c);
  c++;
  Serial.println("For IR Scope: ");
  for (int i = 1; i < count; i++) {
    if ((i % 2) == 1) {
      Serial.print("+");
      Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
    else {
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
  Serial.println("");
  Serial.println("For Arduino sketch: ");
  Serial.print("unsigned int raw");
  Serial.print(c);
   Serial.print("[");
  Serial.print(count, DEC);
  Serial.print("] = {");
    if ((i % 2) == 1) {
    else {
      Serial.print((int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(",");
  Serial.print("};");
  Serial.println("");
  Serial.print("irsend.sendRaw(");
  Serial.print("raw");
  Serial.print(c);
  Serial.print(",");
  Serial.print(",38);");
  Serial.println("");
  Serial.println("");
void loop() {
  if (irrecv.decode(&results)) {
    dump(&results);
    irrecv.resume(); // Receive the next value
I then took the 24 bit array and copied it into a transmitting sketch.
 * IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
 * An IR LED must be connected to Arduino PWM pin 3.
 * Version 0.1 July, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
 */ //   http://www.instructables.com/id/Arduino-Remote-Control-Less-10/?ALLSTEPS
#include <SoftwareSerial.h>
SoftwareSerial BT(10, 11); // TX, RX
String readdata;
IRsend irsend;  // An IR LED must be connected to Arduino PWM pin 3.
 //here put your raw code//
unsigned int raw1[24] = {1250,450,1300,400,400,1300,1250,450,1250,450,400,1250,450,1250,450,1250,450,1250,400,1300,400,1300,1250,};
void setup()
  Serial.begin(9600);
   BT.begin(9600);
void loop() {
  delay(3000);
  irsend.sendRaw(raw1,24,38);
  Serial.println("Sending Code");
When uploaded to the arduino with an infrared led I know it transmits properly since I ran the receiving sketch on a separate arduino and it was able to capture the the RAW codes from the transmitting one, however it won’t turn on my heater. I have tried recapturing the codes and changing the infrared leds but no matter what It won’t turn on the heater. Any advice to get it to work properly?
You may want to check your diodes… check out these videos, this Youtuber had a similar project and ran into a similar issue:
https://www.youtube.com/watch?v=gADIb1Xw8PE
https://www.youtube.com/watch?v=5yyy7h7qh80
https://www.youtube.com/watch?v=sttQAL4r4TQ
