Ir distance sensor and Servo motor
How much current can you source from an Arduino?
I am using an IR distance sensor and a servo. I want to know If i can power both of them from my Arduino UNO.
IR distance senor: http://www.sparkfun.com/products/242
Servo motor http://www.sparkfun.com/products/9064
40ma per I/O pin. I know it works for the IR sensor, and its enough for the control signal on the servo, however the power line on the servo should be plugged into the 5v rail.
