Is there a way to use the OpenMV Global Shutter Module with other boards?
The small form factor and high frame rate of the OpenMV Global Shutter Module is well suited for my application, but the OpenMV Cam H7 board is not able to run the image processing algorithms I need. Is there a way to use the global shutter module with another board, such as a Raspberry Pi 4? Perhaps through an intermediate board that can provide a MIPI or USB interface? Or perhaps there’s an even more director method?
https://www.sparkfun.com/products/16775
Technically, where there’s a will there is a way. But we don’t know of a way to do this. Unfortunately, since we haven’t attempted this type of modification, we can’t support it.
I appreciate the fast response. Is there perhaps a way to use the H7 board itself for this purpose? It already sends a live image feed over USB to the OpenMV IDE, so I’m wondering if there may be a way to access this data directly. I believe this is a compressed data stream, but that may be fine for my purposes. Thanks!
