Hi guys,
I want to measure if there is oil on water. Which sensor can I use for this?
Marijn
Hi guys,
Marijn
Done your homework? What do professionals use?
There are expensive equipment available but out of our budget. I was thinking about measuring the conductivity but I can’t find sensors for it which aren’t 200 dollar+
You have any idea?
You haven’t provided enough information for anyone to make a recommendation.
How much oil do you think will be “on the water” – a film a few molecules thick, or 1 cm?
What type of water? Open ocean, lakes, streams, tap water, down in a well?
Will the water be tested in a small container in the lab, or out in the open?
Measure the amount of refraction.
MarijnB:
There are expensive equipment available but out of our budget. I was thinking about measuring the conductivity but I can’t find sensors for it which aren’t 200 dollar+You have any idea?
Optics.
But find out how the professional/product systems do it. Then try to DIY.
Don’t start with first principles!
