The board LPC-H2148 from Olimex have 2 jumpers with the name:
L_E
DBG_E
What is the function of every jumper?
I think that the Jumper DBG_E is for debuger, but is necessary to programm the uC using the JTAG?
L_E
DBG_E
You need to check them in the schematic against the data sheet, and see what functions the pins they connect to perform. DBG_E probably enables the JTAG, you need to disable JTAG to use ISP with the UART.
Leon
Leon is correct about the DBG_E jumper. If you have L_E jumpered, then you can turn on/off the LED that is connected to P1.24.
