Sorry I know this is going to tick some people off because its probably been asked before. I have a nano, set to nano, ATmega328, /dev/cu.wchusbserial620, ArduinoISP, but the programmer i’ve tried pretty much all of them. Anyways, i keep getting this error message:Arduino: 1.6.12 (Mac OS X), Board: “Arduino Duemilanove or Diecimila, ATmega168”
Build options changed, rebuilding all
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
Sketch uses 928 bytes (6%) of program storage space. Maximum is 14,336 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 1,015 bytes for local variables. Maximum is 1,024 bytes.
/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino6/bin/avrdude -C/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino6/etc/avrdude.conf -v -patmega168 -carduino -P/dev/cu.wchusbserial620 -b19200 -D -Uflash:w:/var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_603276/Blink.ino.hex:i
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:22:25
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino6/etc/avrdude.conf”
User configuration file is “/Users/svteacher/.avrduderc”
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial620
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
This report would have more information with
“Show verbose output during compilation”
option enabled in File → Preferences.
I looked at a few links online and some Arduino pages and articles, but still cant figure it out. I’ve been at it for two hours, and just want an answer. Thanks you guys!
