large digit driver for 10in digit which is used for advert boards
Hi, I have purchased a large digit driver and I want to use shifter on the large display, see link.
Is this possible? I will be using ESP32 as well.
https://www.aliexpress.com/item/3283812 … 0879447_11
Thanks in advance.
No - The item linked is just on/off, you can’t control the segments (other than power…but you’d need to run the wires to a common)…but you can with this one https://www.sparkfun.com/products/8530
They don’t give enough information to really say. Provided the segments use a low enough voltage and don’t draw too much current, you should be able to wire them as a 7 segment common anode display. You’ll probably have to get a set and give it a try.
